Sliding interface between two fluids
Old   December 5, 2020, 02:22
Default Sliding interface between two fluids
Abbas Raza
Abbas20000220 is on a distinguished road
Hi to all,
I have two fluids (one is air other is Licl solution). I used design modular for modelling having dimension 100mm Length and 100mm width for a rectangular plate and their thickness 2mm. I want a membrane to be inserted in between two fluids ( having thickness 0.1mm) while length width = 100mm.
Approach : I made two rectangular plates ( in xy plane) one is for air, while other is for licl solution. giving distance 0.5mm between them along zaxis. While importing mesh, I named all inlets, outlets, and air interface and licl interface respectively. I used default mesh option and moved toward setup. where I used (mesh interface option) for joining these interfaces as a membrane wall and its shadow has also been made.
What I am facing the membrane is appearing when I am clicking on showing mesh at surfaces. But what I want to see contours of temperature in post processing option even though I have given the thickness of membrane. The message I am getting is : Empty surface zone cannot be created.
Seniors please help me out. My approach is wrong or anything is missing in my settings?
Thanks in advance.
Regards,
Abbas
Abbas20000220 is offline   Reply With Quote
ansys, ansys meshing problem, fluent, geometry ansys, sliding contact
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 02:44
Out File does not show Imbalance in % Mmaragann CFX 5 January 20, 2017 11:20
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
[Other] An appropriate Mesher for creating sliding interface sasanghomi OpenFOAM Meshing & Mesh Conversion 2 May 5, 2013 16:24
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
