Different visualization between Fluent and ANSYS CDF post processing results
Old   December 4, 2020, 14:38
Default Different visualization between Fluent and ANSYS CDF post processing results
Gianmario Ledda
Gianmario28 is on a distinguished road
Good morning to everyone,
I'm trying to model an underexpandend jet impinging a cylindrical obstacle in a square box that is reduced to 1/4 for symmetry.
I make my simulation with ANSYS Fluent and it reaches the convergence criteria. When I visualize the contour plot of the velocity the solution is consistent and I can see the formation of the Mach disk, as predicted by theoryvel_fluent.png.
Meanwhile, when I visualize the same contour plot in CFD post-processing result I obtain a wrong solution when it is possible to see a discontinuity in the velocity fieldvel_CFDpost.jpg.
I don't understand because I have this difference, someone can help me?
Thank you,
Gianmario
Gianmario28 is offline   Reply With Quote
Old   December 7, 2020, 00:30
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
use the same range for both pictures
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   December 7, 2020, 05:23
Exclamation
Gianmario Ledda
Hi Alexander, thank you for your reply.
I try to use the same range, but the problem persists. Especially the discontinuities in the velocity flow filed shows in the CFD post-processing.
Thank you for your time!
ansys, cfd, cfd - post, fluent
Data Export From Fluent and Ansys Post Processing Patelp1996 FLUENT 0 September 18, 2020 01:54
Post processing in ansys fluent @nkur FLUENT 0 March 1, 2019 15:10
Post processing in CFD Post or Fluent. Blobs OpenFOAM Post-Processing 2 June 26, 2016 08:23
Can you help me with a problem in ansys static structural solver? sourabh.porwal Structural Mechanics 0 March 27, 2016 18:07
Need help in post processing of Slurry flow in Ansys Fluent jatin1990 FLUENT 0 November 5, 2014 15:11
