UDF Airfoil SHM flapping motion not executing, rather rotating 360degs
Old   December 4, 2020, 01:59
Exclamation UDF Airfoil SHM flapping motion not executing, rather rotating 360degs
AfreedFaizan
AfreedFaizan is on a distinguished road
I'm working on oscillating airfoils based on flapping wings. In order to do so, I took a simple airfoil and made the geometry. I had no issues while building the "udflib" and the code which I used given below. Once I set the CG location and preview the motion. It is rotating 360 degs at a very fast rpm rather than executing slow shm. I'm pretty sure it's something to do with the software rather than the code. Please help me because this is my uni project.
#include "udf.h"
#define Freq 5 % defining flapping frequency i.e 5, 6, 7, 8, 9 and 10Hz
#define PI 22/7
#define angular_freq 2.0*PI*Freq % defining angular frequency
#define tetmax 30.0*PI/180 % defining angular amplitude
DEFINE_CG_MOTION (shm, dt, cg_vel, cg_omega, time, dtime)
real omega;
omega = tetmax *angular_freq* cos (angular_freq *time);
cg_vel[0] = 0.0;
cg_vel[1] = 0.0;
cg_vel[2] = 0.0;
cg_omega[0] = 0.0;
cg_omega[1] = 0.0;
cg_omega[2] = omega;
AfreedFaizan is offline   Reply With Quote
Old   February 18, 2024, 08:11
johnny simson
bored_bot is on a distinguished road
hey any fixes? im facing the exact same issue.
bored_bot is offline   Reply With Quote
Old   February 18, 2024, 10:06
Lightbulb
johnny simson
#define PI 22/7
You could try the following things:
1) change the PI macro definition, instead of that you invoke M_PI instead
2) the reason it rotates instead of executing a simple harmonic motion is because the angles are inconsistent.
so here's the fixed code:
#define angular_freq 2.0*Freq*M_PI/180
Hope this fixed your code!
airfoil pitching 2d, fluent - udf, fluent - udf - parallel, shm not snapping, udf cg motion
How to define movement/deformation relative to a rigid body motion in Fluent by udf? eagle_001 Fluent UDF and Scheme Programming 6 May 17, 2022 04:41
SU2 AOA optimization 454514566@qq.com SU2 9 March 7, 2022 17:17
trying to write a UDF for rigid body motion niteshrajput Fluent UDF and Scheme Programming 4 December 17, 2014 01:29
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
UDF for Airfoil in Circular motion (2D) sohail_27 Fluent UDF and Scheme Programming 4 October 4, 2010 14:36
