Design Points and Report Definitions
Old   December 2, 2020, 00:01
Default Design Points and Report Definitions
elochana is on a distinguished road
Dear All,
Ansys v. 19R2
I ran the simulation for a few design points in workbench. I retained data at all the design points. After completion, I want to extract some other data I didn't create an output parameter for at the begining. So I created a report definition in FLUENT and extracted the data for the current design point. But, when I set another design point as current and try to extract the same data, it spits out the previous (default Current design point) value.
Then I opened a report definition I had created before running the simulation (for which I had set an output parameter). Still when I press compute it spits the value corresponding to the default current design point.
Any advice to get around this problem would be greatly appreciated.
Thank you
elochana is offline   Reply With Quote
design points, parameters, report definition, set as current
[snappyHexMesh] Help with Snappy: no layers growing GianF OpenFOAM Meshing & Mesh Conversion 2 September 23, 2020 09:26
[blockMesh] mergePatchPairs reducing a face to less than 3 points aow OpenFOAM Meshing & Mesh Conversion 2 June 1, 2018 18:37
Difference between Monitor Points and Scene Values. How that? renee STAR-CCM+ 1 October 21, 2013 04:50
Saving the 'Table of Design Points'. rae ANSYS 0 September 16, 2011 03:38
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
