Ansys fluent
Old   November 30, 2020, 19:50
Default Ansys fluent
Jack SSIlver
jackss is on a distinguished road
I am trying to line up an experimentally determined wall pressure spectrum due to turbulent fluid flow to my simulation results in ANSYS FLUENT. However, I have tried nearly all solvers ( LES etc.) and the pressure spectrum that i am obtaining in FLUENT is wayyy larger in magnitude. Can anyone help?
jackss is offline   Reply With Quote
Old   December 2, 2020, 04:39
Default I can help you out
DJF
DJF is on a distinguished road
I've used LES in Fluent in the past to analyze pressure loads and spectra on an inclined plate. Need some more details though.
DJF is offline   Reply With Quote
Old   December 2, 2020, 11:50
Jack SSIlver
In terms of the boundary conditions, the only thing that i am inputting is the inlet velocity and with the LES model, i am using "no perturbations" . The outlet pressure is (by default) set to 0 pascals. With the LES model, I am using WALES
In terms of the mesh, I am using only an inflation mesh ( in some simulations) which generate millions of elements. Some simulations i use both the body sizing and inflation mesh.
In terms of the time step, i am using 200, but i dont think that should be an issue.
Also, I forgot to mention ( my apologies) that it is fluid flow through a pipe that i am simulating.
Old   December 2, 2020, 11:51
Jack SSIlver
Old   December 12, 2020, 02:20
Dnyanesh Mirikar
DnyanMiri is on a distinguished road
I can help you with your problem but I have not understood your problem clearly.
May I ask why are you using LES for simple problem of flow through a pipe? What are the values of y plus for simulation you performed? more information is needed about turbulence as well as wall functions used if any.
DnyanMiri is offline   Reply With Quote
Old   December 21, 2020, 20:04
Jack SSIlver
Hello, I am using LES because it showed the most potential amongst other solvers. The values for the y+ is around 0.001 . For the turbulence, I used no purtibations and well the solver was LES (WALE). Based on reading, I am thinking that when doing the LES, my y+ value should be 1 ?
Old   December 21, 2020, 23:08
Dnyanesh Mirikar
I would suggest you to do a quick RANS simulation for your setup and see if the values of pressure are coming as expected. If they are in the proximity then you can move to LES if you want, otherwise check the setup Boundary conditions, reference values etc. Y+ <1 values are recommended when your resolving viscous sublayer near the wall. And for LES you have to use very fina mesh to get its advantages.
Old   December 22, 2020, 11:03
Jack SSIlver
Thanks for your reply. If my y+ values is around 1e-7 , is that too small and unpractical ? because i noticed when my y+ value was around 0.001, the results looked okayish but when i increased the inflation mesh to a large number of layers ( say 50), the results were not good at all. I am uncertain if the extremely small values of y+ is causing an error or is it actually giving me the 'correct' values ?
Old   December 25, 2020, 08:00
Melih Meriç
mmntmflx is on a distinguished road
1. How much is your flow velocity?
2. So much inflation layer can reduce your mesh quality thats why you can reach poor results. For ex., aspect ratio is directly effected from inflation layers.
3. Just be sure your mesh quality first such as element quality, aspect ratio and skewness values.
mmntmflx is offline   Reply With Quote
Old   December 30, 2020, 20:57
Jack SSIlver
Thanks for your response ! My flow velocity is around 95 m/s. When I check my mesh quality, it isnt that great butI have tried other types of mesh but the results are not good. The only good ( not great) results I am getting is with the inflation layers but the mesh quality isnt that great.
A next issue I was having is that when I reduce the element size using the 'body sizing' option, the results that I were getting were very erroneous. Can you suggest anything again? Thanks for your replies, I really appreciate it.
ansys, experimental, fluent, pressure spectrum
GPU acceleration in Ansys Fluent flotus1 Hardware 63 May 12, 2023 03:48
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 04:34
Using ANSYS Fluent 18.0 on workstations with multiple network cards and PBS Pro cheezum Hardware 0 February 28, 2017 11:23
How to combine ANSYS Fluent and Structural analysis? diwakar ANSYS 2 June 18, 2015 13:07
error in opening fluent in ansys workbench tmeysam92 ANSYS 3 March 12, 2013 07:10
