The accuracy of exported solution data in FLUENT |
November 30, 2020, 11:04 |
Amir
Rep Power: 7 |
Hello all,
I post-process FLUENT solution data in MATLAB so I need to export the data from Export>solution data> ... in ASCII format. There is a situation that discerning convection from a static solution is crucial so I need to know the Nsselt number. The heat flux that I write in a file in the above manner has 10 significant digits. Calculating Nusselt number (Nu) from the above data gives me Nu =1.000000000 which is quite surprising as I worked with other CFD software and did not get Nu as accurate! Thus, I suspect that the calculated heat flux by FLUENT is actually 10 significant digits accurate. My question is: how can I find the actual accuracy of the exported data from FLUENT? Thank you, Amir |
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
Reading Additional Data Quantities from Fluent into Tecplot | fremder | Tecplot | 9 | December 16, 2016 15:35 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
fluent 13 export solution data | Zyryx | FLUENT | 1 | November 11, 2011 10:09 |
intializing data in fluent from an available solution( from an opensource code) | ayannath23 | FLUENT | 1 | December 21, 2010 12:54 |
