Change Boundary Condition type during Transient simulation
Old   November 27, 2020, 05:30
Smile Change Boundary Condition type during Transient simulation
Achille
Achille is on a distinguished road
I am asking for your help for a boundary condition problem in a 2D model. I have a pipe on which I would like to apply a temperature to one of the surfaces. However, after a while, I want to remove this boundary condition and let the heat flow freely through my pipe. It's a bit like heating an iron bar in a fire (I impose my temperature), then removing it from the heat (I remove my limit condition) to see how the surface temperatures evolve.
(I know that it is possible to impose a temperature and make it vary over time thanks to the UFDs, but that's not what I want to do).
Thank you in advance your knowledge sharing
Achille is offline   Reply With Quote
Old   November 29, 2020, 21:59
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
describe your model (mesh) and why UDF doesn't work for your case.
you may change type of boundary condition manually or using TUI command
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   December 5, 2020, 09:58
Achille
Sorry if it was not 100% clear, I will try to give you a better understanding of my problem.
I am running a transient simulation and I would like to change the boundary condition at a specific time tc in a line l1 surrounding a 2D pipe (photo) :
if t<tc : set a temperature boundary condition to l1 : T=constant
if t>tc : set a heat flux boundary condition to l1 : Φ = 0
Is it possible to perform that using TUI commande or UDFs ?
If it's possible, please, can you show me the code I need to write ?
Old   December 29, 2022, 11:20
Behrouz
BehrouzMohammadian is on a distinguished road
Hello, I have the same problem. Did you find any solution for it?
Thank you,
BehrouzMohammadian is offline   Reply With Quote
change boundary condition, transient 2d
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
multiphaseEulerFoam/tank discharge ves OpenFOAM Running, Solving & CFD 8 December 31, 2017 15:59
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Error during initialization of "rhoSimpleFoam" kornickel OpenFOAM Running, Solving & CFD 8 September 17, 2013 06:37
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
