November 21, 2020, 07:08 |
Rotating Region - Results
Manolis Theofilos
Rep Power: 6 |
Hi All
I am trynig to perform a stady state simulation on a small fan, 90mm nominal diameter. I have set up 3 fluid domains, one upstream of the fan, one for the rotating region, encompassing the fan impeller, and one downstream of the fan with 12 hydraulic diameters in length. The fan is rotating clockwise at 13000 rpm My simulation converges (I still need to refine the boundary layers for y+), however when I go to post processing the pathlines deflect counterclockwise the instance they reach the interface of the rotating region and then again deflect clockwise downstream. The downstream behaviour is what I would expect, with a swirling motion that will need some time to normalise. I have set my rotating region to Frame Motion, rotating about the Z axis, and "absolute" in the Relative to cell zone option I have also set the rotating region wall as a stationary wall The Impeller has been set up as a wall in the boundary conditions and I have tried having it rotating along the Z axis with an Absolute motion, I have also tried having it as a Stationary Wall relative to the Adjacent Cell Zone and Finally I have tried having it as a rotating wall Relative to the Adjacent Cell Zone. The results in all 3 options are the same when it comes to the pathlines. I would expect the pathlines to be deflected clockwise and have the same swirling motion in the rotating region as well as in the downstream region. Inlet is a pressure inlet, outlet is a pressure outlet and due to the close interaction between the blade tip and the wall I have selected the k-w SST turbulence model. Am I missing something, or doing something wrong? Pathlines.jpg |
November 21, 2020, 16:53 |
#2 | |
Manolis Theofilos
Rep Power: 6 |
I've lost 2 days thinking I was doing the setup wrong, read countless papers and manuals for Fluent's current and previous versions and it was that simple. |
Negative initial temperature error (chtMultiRegionFoam) | jebin | OpenFOAM Pre-Processing | 60 | July 17, 2022 06:10 |
results in rotating frame for chtMultiRegionFoam | atlan | OpenFOAM Post-Processing | 0 | September 8, 2016 09:03 |
Car external aerodynamic with wheel spinning issue | hokhay | FloEFD, FloWorks & FloTHERM | 2 | August 18, 2016 05:23 |
MRFSimpleFoam - Selection of rotating region | Ivanet | OpenFOAM Running, Solving & CFD | 8 | May 22, 2015 10:17 |
Rotating Region and mesh size | QuentinMercier | Autodesk Simulation CFD | 1 | May 29, 2013 15:12 |
