Define Monitor as a temperature matrix across the surface. |
November 19, 2020, 12:53 |
Anooj
Rep Power: 5 |
Hi
I am running fluent simulations for phase change process. I need to extract temperature as a matrix, each element of matrix corresponds to a temperature of a point on the surface. I found it very hard to define a separate monitor for each point and save it to file. I am using Fluent 18. Thanks in advance. |
November 20, 2020, 02:27 |
Moritz Kuhn
Rep Power: 17 |
If you can update your fluent, do it. From 19 it is possible to store different monitors to a single file.
November 20, 2020, 03:31 |
Anooj
Rep Power: 5 |
Thanks for the reply, In fluent 18 I can store them in single file
It's not about storing then in a single file, I have to manually define a monitor for each point. |
November 20, 2020, 03:40 |
Moritz Kuhn
Rep Power: 17 |
If you know the coordinates, try to write a journal.
November 23, 2020, 01:12 |
Alexander
Rep Power: 34 |
from my point of view,
easiest way actually is define all points. you may define list of this points which contains coordinates. Once it is done, read this list using journal, to create points automatically. Also, you may write data to file using UDF. In that case you will still need list of coordinates. UDF is more tricky
best regards ****************************** press LIKE if this message was helpful |
fluent 18.1, monitor points, temperature matrix |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
problem in temperature and liquid fraction value in the udf | durg | FLUENT | 0 | October 23, 2018 01:52 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
Temperature growth from hot coil surface | L. Hamid | Main CFD Forum | 0 | December 17, 2013 06:38 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
