November 15, 2020, 21:15 |
Hot flow does not go cross the next domain.
Alfin Pohan
Rep Power: 6 |
Hello there.
I am simulating a cylinder that heated by hot air, my problem is that the flow seems like dont go to the cylinder itself. I have 2 domains both defined as fluids i callled the cylinder as a drum. The flow seem does not hit the drum, but when i set the contour around the interface around the drum it is just stop there but does not influence the temperature of the drum. Is there anybody can help me figure it out? |
November 16, 2020, 08:53 |
Moritz Kuhn
Rep Power: 17 |
It seems that your two domains are not properly connected. What is the type of the boundary between them? It has to be interior.
November 26, 2020, 03:22 |
Alfin Pohan
Rep Power: 6 |
I am terribly sorry for replying this too latee. Btw its interface but i supressed the contact region between it and i got 1 boundary in the drum then i set it as a wall.
November 26, 2020, 04:42 |
Rep Power: 27 |
So you replaced the interface by a wall, and now you ask why you see a wall in your results?
November 26, 2020, 05:02 |
Alfin Pohan
Rep Power: 6 |
November 26, 2020, 19:42 |
Alexander
Rep Power: 34 |
you need to have interior or coupled interface boundary condition between fluid regions
best regards ****************************** press LIKE if this message was helpful |
November 28, 2020, 04:28 |
Rep Power: 27 |
November 28, 2020, 05:54 |
Alfin Pohan
Rep Power: 6 |
I was trying si hard to make it ad interior sir, btw i am a newbie.
November 28, 2020, 09:30 |
#9 |
Rep Power: 27 |
I am not making fun of you. I'm trying to show you that Fluent just followed your instructions.
Don't feel attacked because somebody answered your question. |
November 28, 2020, 10:09 |
#10 | |
Alfin Pohan
Rep Power: 6 |
I admited that i am a newbie. Sorry if i made some mistake that offend you. |
November 28, 2020, 21:44 |
#11 |
Rep Power: 27 |
I don't know why you react like this. Nothing offended me, I never said something offended me, I never hinted that something offended me, I only tried to help you with your question.
But if you keep repeating that you are a newbie and suggest that I am being bad to newbies: that is a good way to offend me. |
November 28, 2020, 23:11 |
#12 | |
Alfin Pohan
Rep Power: 6 |
Do you have some suggestion like what should i do now sir about my simulation? I need that so bad. Thank you. |
November 29, 2020, 04:43 |
#13 | |
Rep Power: 27 |
Now you probably did.that for a reason. I don't know the reason, I can't look inside your head. I can only guess. My guess is that the interface gave you errors, and you did this to solve the error. If that is true, then this is the wrong approach. (but don't feel bad for trying!) The error should be fixed in another way. But I need more info on WHY you did this, before I am able to say how it can be solved. |
November 29, 2020, 04:59 |
#14 | |
Alfin Pohan
Rep Power: 6 |
The flow i defined from the pipe was not go out to the outlet, it just hit the drum and dissappeared. |
November 29, 2020, 05:53 |
#15 | |
Rep Power: 27 |
So your first problem was that you were not able to get a wall for the drum. Start with that. First of all: I don't understand this. The wall is the default boundary, how were you not able to get this? What did you get instead, an inlet? An outlet? What makes you say that you did not get a wall? And what does this wall for the drum have to do with the interface between the drum and the cylinder? |
November 29, 2020, 06:00 |
#16 |
Alfin Pohan
Rep Power: 6 |
I only got two interfaces sir, they are interfaces for drum and also the housing domain. I could not be able to swith it as a wall. But when i deleted a mesh connection in ansys fluent that attaching both interfaces once i was able to set it as a wall, it said the interface unassigned.
November 29, 2020, 11:19 |
#17 |
Rep Power: 27 |
No no, don't change the interface into a wall!
Why are you trying to make the interface a wall? Stop that! Do you know what an interface is? Do you know what a wall is? Are you sure you are using the term "interface" correctly? Because I can't make any sense of why you think this is a good idea. |
November 29, 2020, 11:21 |
#18 | |
Alfin Pohan
Rep Power: 6 |
November 29, 2020, 11:25 |
#19 |
Rep Power: 27 |
Load your model, and look at the cell zones.
You probably have: -interiors (at least two in your case) -interfaces (at least two) -walls (at least two) Is that right? |
November 29, 2020, 11:28 |
#20 |
Alfin Pohan
Rep Power: 6 |
Strange behaviour: Ethanol solution flow on channel with interface to porous domain | khariel | CFX | 6 | December 11, 2014 18:08 |
Floating point exception: Zero divide | liladhar | CFX | 11 | December 16, 2013 05:07 |
Modeling the flow domain in Icepak | saisanthoshm88 | ANSYS | 1 | December 12, 2011 01:20 |
Modeling the flow domain in Icepak | saisanthoshm88 | Main CFD Forum | 0 | April 11, 2011 09:31 |
Water jet in confined hot air cross flow | Jim Clancy | FLUENT | 0 | November 24, 2007 17:14 |
