November 29, 2020, 10:35 |
#21 |
Rep Power: 26 |
Good.
The interfaces make it possible for flow to go from one interior to the other. You want flow to go from one interface to the other, so keep them. You say you want a wall in the drum. Good news: you probably already have it! One of the cell zones that is a wall should do the job! So, it looks like everything is set like you want. Why are you changing things? |
November 29, 2020, 11:05 |
#22 | |
Alfin Pohan
Rep Power: 6 |
November 29, 2020, 11:21 |
#23 |
Rep Power: 26 |
What makes you say you don't have a wall?
What happened to the boundary of the drum? By default that should be a wall, and you confirmed that your case has walls. So you have a wall! |
November 29, 2020, 11:58 |
#24 |
Alfin Pohan
Rep Power: 6 |
I have 2 walls which are the pipe and the housing, the drum inside set itself as contacts region(interface) sir.
November 29, 2020, 12:15 |
#25 |
Rep Power: 26 |
Is the volume of the drum included in Fluent? Is it meshed?
If so, did you make the cell zone solid? |
November 29, 2020, 12:20 |
#26 |
Alfin Pohan
Rep Power: 6 |
November 29, 2020, 12:26 |
#27 |
Rep Power: 26 |
? That makes no sense...
You want it to have a thickness of 2mm. So something solid. Then make it solid! What does 2 mm have to do with making it fluid? It physically is solid, make it solid! If you want a solid of 2mm, make it 2mm in your geometry! I don't know how to respond better, I can not follow your logic. |
November 29, 2020, 13:57 |
#28 | |
Alfin Pohan
Rep Power: 6 |
I am sorry sir pak, if its lead us to a confusion. |
November 29, 2020, 15:38 |
#29 | |
Rep Power: 26 |
1: don't mesh the drum interior, but only mesh the boundary faces; set the thickness of the shell elements at 2mm. For fluent, this is just a fluid boundary condition. 2: mesh the 2mm solid, and put solid elements there. There will be a solid-fluid boundary, I think in Fluent it's called wall-shadow wall. Both options work fine. Results are not identical, but close enough, if the 2mm is small enough relatively. But you did something else: 3. Mesh the complete drum, make it liquid, but then make the interface a wall so that the liquid is not connected anymore to the rest. I don't know why you did that, and I've tried many times to tell you that you should not do that. If the drum is not liquid, don't model it as liquid! It seems very logical to me. |
December 2, 2020, 15:48 |
#30 | |
Alfin Pohan
Rep Power: 6 |
Strange behaviour: Ethanol solution flow on channel with interface to porous domain | khariel | CFX | 6 | December 11, 2014 17:08 |
Floating point exception: Zero divide | liladhar | CFX | 11 | December 16, 2013 04:07 |
Modeling the flow domain in Icepak | saisanthoshm88 | ANSYS | 1 | December 12, 2011 00:20 |
Modeling the flow domain in Icepak | saisanthoshm88 | Main CFD Forum | 0 | April 11, 2011 08:31 |
Water jet in confined hot air cross flow | Jim Clancy | FLUENT | 0 | November 24, 2007 16:14 |
