Overset meshing problem in Fluent
Old   November 14, 2020, 07:06
Default Overset meshing problem in Fluent
B_L_ is on a distinguished road
Hello
I'm doing a 2D analysis of the flow around two gears. I have created structured meshes around both components and a structured background mesh. After starting up Fluent (2020R2), the overset option is not available and no background or component zones are found. The single meshes are displayed overlapping in fluent, but an interface cant be created. The boundary conditions can also not be set to overset.
I have used overset in 3D Problems before and it always worked fine.
Does anyone have an idea what may cause the Problem?
Tanks in advance
B_L_ is offline   Reply With Quote
Old   November 15, 2020, 01:08
Shivank
Shiv1510 is on a distinguished road
Hi
Have you named any boundaries as overset in meshing/ or anywhere when you name it eg, wall, inlet, outlet etc ?
Shiv1510 is offline   Reply With Quote
Old   November 15, 2020, 03:54
Hi, thanks for your answer.
I named all boundaries accordingly to their functions while meshing. I actually resolved the problem by loading the Workbench Project onto a different computer (same Fluent Version).
I dont exactly know why, but on the other PC it instantly worked...
Old   November 15, 2020, 15:05
Shivank
Ok, that is great. Hey if I may ask, what post processing tool are you using to generate contour plots for overset mesh simulations ? CFD post does not do well !
Old   November 16, 2020, 02:06
I just use the built in post processing tools in Fluent (at the bottom of your toolbar). You can create Contours/Vectors/Animations etc. very well in Fluent and its compatible with overset.
overset, overset fluent
[ANSYS Meshing] Help with Ansys Meshing for fluent overset grid ramkr ANSYS Meshing & Geometry 0 September 7, 2019 03:03
Fluent meshing skewness vs Fluent skewness Jiricbeng FLUENT 2 January 10, 2019 11:19
6DOF Dynamic Mesh Problem with Overset Meshing - Weird velocity contour Caster_Troy FLUENT 1 December 7, 2017 07:19
facing problem in dynamic meshing motion preview in fluent hitesh0401 Fluent UDF and Scheme Programming 6 May 8, 2014 16:59
[ICEM] Meshing problem from ICEM CFD to Fluent cfdonlinederafa ANSYS Meshing & Geometry 2 September 21, 2010 17:16
