Problem in Sun direction vector ANSYS fluent
Old   November 13, 2020, 21:25
Unhappy Problem in Sun direction vector ANSYS fluent
Ahmed elkiki
Ahmedelkiki is on a distinguished road
Please I am working on simulation of solar still I wanted to add a solar radiation so I used solar loading and used solar ray tracing and used solar calculator to define my sun direction vector instead of entering it manually the direct and diffused beam I know their values so I define them as constant value for that certain hour so I only use the solar calculator to compute the sun direction vector
My problem is that the sun rays seems to be under the solar still not above it so I want to learn If anyone knows how to probably define the sun direction vector from a certain correlation or from the solar calculator it seems I doesn't understand the mesh orientation how to define it
Thanks
Ahmedelkiki is offline   Reply With Quote
fluent - parallel, multi phase, radiation model, solar still
Stefan problem using fluent Isaacibp1401 Fluent Multiphase 2 June 7, 2021 06:49
Strange Mesh Problem in Fluent alpcfd FLUENT 1 October 8, 2020 13:47
Problem with Volumetric Reactions in Fluent Kashif Rashid Fluent UDF and Scheme Programming 2 December 28, 2017 01:36
fluent parallel problem in win7 x64 system dunga82 FLUENT 8 April 19, 2012 21:23
fluent convergence problem josip76 FLUENT 0 May 26, 2011 21:08
