fluid Domain without Boundary Conditions
Old   November 12, 2020, 10:54
Default fluid Domain without Boundary Conditions
flashpointer is on a distinguished road
Hi
i cannot figure out how to define the initial pressures in my case in fluent:
in short we have two chambers, one is closed and filled with compressible gas, the other one with incompressible fluid and comes with an inlet. These chambers are separated with a piston. As we starts to fill the incompressible side, the piston should move and compress the gas chamber with increasing system pressure.
i alredy have an FSI setup with the two faces but how can i defined the initial gas chamber Pressure without BC? and also cannot setup any pressure with only an inlet at the inlet-side.
flashpointer is offline   Reply With Quote
Old   November 16, 2020, 09:09
Moritz Kuhn
MKuhn is on a distinguished road
With the standard initialization method you can initialize with a certain pressure. Or use hybrid initialization method (in this case fluent will initialize with the operating pressure) and use the patch option to overwrite the pressure settings.
MKuhn is offline   Reply With Quote
initial condition, pressure
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 07:08
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Low torque values on Screw Turbine Shaun Waters CFX 34 July 23, 2015 09:16
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
