Problem in modeling dissociated air in the driven section of a shock tube simulation
Old   November 8, 2020, 07:29
Default Problem in modeling dissociated air in the driven section of a shock tube simulation
Sneh
sneh1306 is on a distinguished road
I am trying to simulate a shock tube flow in Fluent workbench with the driver and driven sections modeled (as two fluid zones), separated by a diaphragm (BC type: interior, ID=3).
I expect high temperature of the test gas in the driven section and have therefore invoked a dissociation model with full reaction chemistry in that zone. The modeled gas is dissociated air (with 5 constituent species). On the driver end, the gas is helium.
However, when I initialize the model, an error shows up saying: 'Species are not solved in neighbor cell threads (6 and 7) of interior zone 3'
Can somebody help me rectify this problem? I tested several things and noticed that if both the zones on either side of the diaphragm are set to the same gas (either helium or dissociated air on both sides), the error does not arise. Also with different gases, if I model one side as helium and the other side as normal undissociated air, the error does not arise. But these are not what I want.
Any leads would be appreciated. Please help.
sneh1306 is offline   Reply With Quote
dissociation modeling, shock tube
Moving piston in a shock tube problem using unsteady, viscous and compressible flows kujjwal Main CFD Forum 0 February 10, 2020 03:13
Moving piston in a shock tube problem using unsteady, viscous and compressible flows kujjwal Mesh Generation & Pre-Processing 0 February 10, 2020 02:44
1D Shock Tube problem RamShivam Main CFD Forum 3 June 13, 2018 10:37
SOD shock tube problem Luuk Main CFD Forum 3 September 6, 2005 06:08
Shock tube problem ger Main CFD Forum 1 September 24, 2003 08:41
