Rotated Airfoil with horizontal Velocity Vs. Horizontal Airfoil with inclined veloci |
November 6, 2020, 11:27 |
Karim Sayed
Rep Power: 6 |
Greetings,
I am carrying out a CFD analysis of SD7032 Airfoil at Re=60000. I am encountering a weird problem. I tried two methods. First, keeping the airfoil in a horizontal position and defining the velocity direction to satisfy the angle of attack, and second, rotating the airfoil with the specified angle of attack and Keeping the velocity in a horizontal direction. The results of drag coefficient are different in both cases. I am using rectangular domain surrounding the airfoil with the following boundary conditions: first case, Velocity inlet from the front, upper and lower sides, and pressure outlet at the rear side, while in the second case, velocity inlet from the front side, walls for the upper and lower sides, and pressure outlet for the rear side. I also tried symmetry, and pressure outlet instead of the upper and lower walls in the second case and they yield almost the same weird result. |
November 8, 2020, 04:23 |
Lorenzo Galieti
Rep Power: 12 |
Are you calculating it in the same direction with respect to the airfoil? I bet that when the flow is inclined and the airfoil is horizontal, you calculated the drag on the X direction rather than the one parallel to the inflow condition
November 8, 2020, 06:51 |
Karim Sayed
Rep Power: 6 |
Yes I calculated the drag in the same flow direction by setting up the x & y components of the drag monitor.
November 10, 2020, 16:07 |
Lorenzo Galieti
Rep Power: 12 |
So in the inclined Airfoil you are taking the x component of the drag and in the inclined flow the X component divided by the cosine of the angle of attack?
November 10, 2020, 18:11 |
#5 | |
Karim Sayed
Rep Power: 6 |
In the inclined Airfoil: Inlet velocity x=1 Inlet velocity y=0 drag x=1 drag y=0 |
November 11, 2020, 03:24 |
Lorenzo Galieti
Rep Power: 12 |
Ok I believe you. Can you post two velocity contours, one for the inclined airfoil and one for the inclined flow? Please use the same scale and try to make the airfoil size more or less equal
Is this velocity distribution around an airfoil plausible? | docinger | OpenFOAM Running, Solving & CFD | 3 | September 21, 2013 15:21 |
Oscillating Airfoil - Dynamic meshing or user-defined velocity profile. | DarrenC | Main CFD Forum | 5 | July 19, 2010 22:33 |
Velocity of 3.5 for oscillating airfoil - logical? | quarkz | Main CFD Forum | 0 | April 13, 2006 00:12 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
