discontinuity when reload case and data to reiterate |
November 4, 2020, 12:15 |
Weiqiang Liu
Rep Power: 9 |
Hi all,
I met a very interesting phenomenon when I tried to read saved case and data file to re-iterate. Firstly, I saved case and data files then I read back the case and data files and started calculating. Interesting thing was that a sudden jump for all residuals happened after iteration started. It seemed I have changed some settings of the model. However, I actually changed nothing of the model. What's worse was the case seemed converged worse due to this discontinuity. I am wondering how can I solve this problem. was something wrong the way I save case and data files? Best regards weiqiang |
January 21, 2021, 11:47 |
Weiqiang Liu
Rep Power: 9 |
Hi, all
This phenomenon is caused by the following reason fluent uses new ISAT table every time it reloads case and date when stiff chemistry solver is used. However, if the case is fully converged, then this discontinuity on residuals won't change final results Best regards weiqiang |
convergence, discontinuity, reload, save |
[OpenFOAM] How to get the coordinates of velocity data at all cells and at all times | vidyadhar | ParaView | 9 | May 20, 2020 21:06 |
Including extra data in case and data export? | thewitcher745 | FLUENT | 5 | July 20, 2017 09:36 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 10:28 |
How to repeat to read the same case without saving case and data file? | lcg44 | Fluent UDF and Scheme Programming | 4 | November 22, 2012 11:45 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 18:27 |
