November 4, 2020, 11:06 |
using User Define Real Gas Model (UDRGM)
Amirreza Niazmehr
Rep Power: 7 |
Hi guys,
We are going to simulate the stream of a gas over a switchgear (the physiks of the problem is not important for you We have our own data (table) for this gas. The ponit is that, for this gas Cp (specific heat) is changing with Temperature and Pressure both. For this purpose I should use UDRGM of Fluent, I studied also the manuel of Fluent but I could not get the Idea of using for my case. The problem is that: I I am looking to define Cp while having different thermodynamics lookup tables giving me Cp as temp and pressure varies. Is there any template of code available for doing so or else any method through which I could calculate the coefficients for the real gas models from the data of the thermodynamic table. Actually I have my own Data (tables) and I want to read them. Can I use UDRGM of Fluent so that I can use my own Data? Sorry, that I explained too much, I just wanted to explain my problem clearly. |
HEM with Fluent: Use NIST Real Gas Model in 2-phase region | c_023 | FLUENT | 2 | April 13, 2022 06:26 |
make a new data from external .txt data and save it in a UDM | etedalgara | Fluent UDF and Scheme Programming | 27 | February 26, 2020 03:15 |
FLUENT 19.2 User Defined Real Gas Model udf problem | MKPP | FLUENT | 1 | June 23, 2019 21:39 |
user defined real gas model | antara | Fluent UDF and Scheme Programming | 0 | October 12, 2015 14:59 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
