large domain with large aspect ratio
Old   October 23, 2020, 03:00
Default large domain with large aspect ratio
ashkan
ashkan0065 is on a distinguished road
hello,
I have a very large domain with a very large aspect ratio. domain is a pool with a very small hole in it. pool is a cube with 10 *10*10 km and the hole diameter is 20 cm!
is there any way to simulate this type of problems without large mesh number? like scaling down or other methods?
thanks very much
ashkan0065 is offline   Reply With Quote
Old   October 24, 2020, 17:16
lei
Lei Chen
lei is on a distinguished road
Hi Ashkan, you may try to solve this problem with probably two methods:
1. use conformal mesh but gradually growing mesh size, you may try to use cut-cell mesh in ANSYS mesher;
2. a more easier way is to use interfaces between the local fine mesh region with small mesh sizes, and a broader region with large mesh sizes. Specifically to your problem, with 5 orders of magnitude change, you may need several transitions to ensure a good continuity convergence;
Other than those, is CFD really the best way to model your km domain? Or you may want to use the CFD results from the small region to provide a B.C. to the larger domain flow problem.
Hope this helps.
lei is offline   Reply With Quote
Sudden increase the residual of Maxwell's equations hsezsz CFX 2 October 13, 2016 06:58
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation volleyHC CFX 5 April 3, 2016 05:41
simpleFoam convergence on large domain kwiik OpenFOAM 43 May 31, 2013 10:10
Question about the large expansion ratio influence to the numerical accuracy Anna Tian Main CFD Forum 8 September 27, 2012 04:54
Grid Aspect Ratio harishameed33 Main CFD Forum 1 August 11, 2012 22:35
