executing a script to output nodal locations at time 0 before moving mesh
Old   October 20, 2020, 09:28
Default executing a script to output nodal locations at time 0 before moving mesh
Tyler Richardson
tricha122 is on a distinguished road
i have a moving mesh with a UDF that ouputs HTC's every X timesteps beginning at timestep Y (after mass flow ramping and rotation ramping).
However, by the time my mass flow and rotation are fully ramped, the mesh is in a different position than the starting position, and is erroneous for mapping to the ANSYS thermal model.
I am looking to execute my UDF (DEFINE_ON_DEMAND) at time zero, and not repeat. how can i do this with the TUI?
currently i execute the following after several rotations (ramping flow rate, and ramping speed):
/solve/execute-commands/add-edit execUDF (rpgetvar'storeudm) "time-step" "/define/user-defined/execute-on-demand "on_demand_calc::HsgUDF""
/solve/execute-commands/add-edit execWRITE (rpgetvar'storeudm) "time-step" "/file/export/ascii hconv_data_%t.csv inflation-rotat_oil_1_elem inflation-static_oil_1_elem inflation-static_oil_2_elem () yes udm-0 () no"
Im hoping to be able to execute the two commands above just prior to my initial solve but not "repeat" so i dont get thousands of files
Any help would be greatly appreciated!
Thanks!
tricha122 is offline   Reply With Quote
Old   October 20, 2020, 09:35
Tyler Richardson
nevermind, i think i just needed to do this prior to solving:
/file/export/ascii hconv_data_%t.csv inflation-rotat_oil_1_elem inflation-static_oil_1_elem inflation-static_oil_2_elem () ()
fluent, tui, udf, udm
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 6, 2023 00:48
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 23:40
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 08:56
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
