October 19, 2020, 13:04 |
Simulating Wind in 3D from real data
Rep Power: 6 |
I am simulating wind over a field in 3d from a real anemometer. The data has 5 inputs from 5 heights of the real sensors. I have created 5 zones with thickness corresponding to each sensors height. I have imported a transient table reading the N/E, S/W, and Z components of the wind for each of the 5 sensors. Originally, I thought I could just use velocity inlets. The domain is square, actually slightly rectangular for the purpose of this simulation, and upon review, I discovered having two whole sides of the domain be a velocity input creates weird flows, especially near the corner where the two sides meet. Basically, I want the incoming wind data to be uniform and not necessarily defined by the faces of the domain. This made me consider using the frame/mesh motion. The first question would be if this is the correct way to handle this? If you were modelling a 3d space and needed the incoming fluid to be uniform (ie not defined by the geometry), would domain motion be the correct assumption? If so, my next question would be whether to use mesh motion or frame motion. This is a new concept to me, so not entirely sure what the difference is. So, basically, the overall question is, what is the best approach to simulate the effects of incoming wind over a domain. If you all need any more detail, let me know. Thanks. |
3d fluid, fluid motion, wind simulation |
[OpenFOAM] How to get the coordinates of velocity data at all cells and at all times | vidyadhar | ParaView | 9 | May 20, 2020 21:06 |
sharing code to calculate PMV, PPD and PD in fluent using UDF | simon02200059 | Fluent UDF and Scheme Programming | 2 | June 24, 2019 02:02 |
UDF for thermal conductivity relation of nano fluid | ngonbadipoor@yahoo.com | Fluent UDF and Scheme Programming | 29 | April 1, 2017 04:02 |
Non-linear equation system (DEFINE_source) | Laexzzz | Fluent UDF and Scheme Programming | 4 | February 11, 2015 17:11 |
[General] 2 datas on one plot | Akuji | ParaView | 46 | December 1, 2013 15:06 |
