Validation setting for bluff body under cross flow |
October 16, 2020, 13:07 |
Amir fit
Rep Power: 7 |
I am trying to do validation for a bluff body under cross flow in fluent. I understand that for getting the Strouhal number, the setting should be viscosity =0.01, density=1, and for Re=100, if the diameter is 1, then the velocity is 1. But in the case of non circular body, which dimension of diameter should I use to calculate the velocity? The flow is in the X-direction. Should I use diameter in the x direction (1m) or y direction(1.5m)? TQ |
bluff body validation, strouhal number |
'2-phase' gas-liquid flow validation on this case. | Ash Kot | FLUENT | 0 | June 1, 2017 19:25 |
2 phase flow validation on this case. | Ash Kot | Fluent Multiphase | 0 | May 31, 2017 04:11 |
The effect of setting parameters on the roll type flow | saharesobh | FLUENT | 1 | February 9, 2013 17:49 |
Turbulent Flow in Straight Square Duct - k-ep Validation | mcclud | STAR-CCM+ | 2 | August 7, 2012 17:56 |
Simulation of Flow induced vibration on an elastically mounted bluff body in a cross | pradeepta | FLUENT | 2 | September 17, 2009 08:18 |
