Electron Density
Old   September 25, 2020, 11:52
Question Electron Density
Sarah.g is on a distinguished road
I am doing 2-d nozzle analysis using fluent. My purpose is calculating electron density in plasma near nozzle exit. I made some assumption w.r.t. that air is my fluid. Electron density is known in combusiton chamber and I am trying to find electron density near nozzle exit doing density proportionality. Although, my flow structure is correct but my electron density is high around two order. Is there a way to change density near nozzle exit, without changing flow structure??
Thanks,
Sarah.g is offline   Reply With Quote
Current density visualisation (PEM fuel cell add-on module) pchoopanya FLUENT 10 August 21, 2023 15:33
Implement simple barotropic relation - derive density field from pressure field GJM1991 OpenFOAM Programming & Development 6 May 8, 2016 16:43
A problem about density in liquid air definition alloveyou CFX 2 June 14, 2012 15:20
REAL GAS UDF brian FLUENT 6 September 11, 2006 09:23
Warning 097- AB Siemens 6 November 15, 2004 05:41
