Heri T
Rep Power: 5 ![]() |
i am analysing cfd analysis of pressurised gas leaving tank. For that to create geometry i used icem cfd. Meshing looks coreect and i modified it for erros too. but when i try to solve using ansys fluent.. fluid: ideal gas turbulence model used: k-epsilon ,relaizable,scalable wall function boundary condition: axis-symmetric wall: convection----287K-----45W/m2K----0.001mm thick operating condition: press:101325, density:1.225,y-gravity:-9.81m/s2 tank inside condition:1013250,550K tank outside condition: 101325,300K ------------------------------------------------------------------------ Divergence detected in AMG solver:k divergence detected in AMG solver: epsilon Error at host: floating point exception Divergence detected in AMG solver Error at node 0: floating point exception -------------------------------------------------------------------------- there can be a problem in meshing too..because i am new in icem cfd. here i am attaching its meshing file and geometry. have a look at it and suggest edit in detail. Thank you. This is the last files i am sharing..i have created other geometries with inflation on all boundaries as well but the error was same in fluent. https://drive.google.com/drive/folde...C6?usp=sharing |
floating point exception, fluent error, icem, icem cfd meshing, pressurised tank problem |
How to define a hole as boundary condition in Ansys Fluent using Fluent an mesh only? | Nagu Sattenapalli | CFD-Wiki | 0 | August 12, 2019 04:03 |
Can you help me with a problem in ansys static structural solver? | sourabh.porwal | Structural Mechanics | 0 | March 27, 2016 17:07 |
Want computer solution for Ansys Fluent | lolersk8ter | Hardware | 0 | October 29, 2013 20:16 |
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 12:07 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
