Periodically fully developed (laminar and turbulent) flow and heat transfer within a |
AA
Rep Power: 5 ![]() |
Periodically fully developed (laminar and turbulent) flow and heat transfer within a 3-dimensional non-circular channel.
Hi everyone, I have heat exchanger of geometry consisting of two paths, one for cold fluid and the other for hot fluid. My geometry is quite large and in order to reduce the fluid domain, I am trying to use fully developed profiles for each of, velocity, pressure fields, temperature, kinetic energy k, and dissipation e. Would it be possible to write a UDF for all of these variables in order to apply them at inlet section ? Is there available code for fully developed profiles of the non-circular conduit? Also, I am looking for temperature profile as fully hydraulically and thermal developed flow , and I couldn't find anything related to non-circular conduit or channels. In the first time, I was thinking to separate the two fluids ( separating the two domains) and using periodic analysis within the Fluent. But the wall temperature is not constant along the wall between the fluids. IF we separate the fluids and consider the wall temperature is constant at each domain, how can we estimate this temperature along the wall as if both fluids is being together? In other words, I can't make thermal analysis on both fluids together to know the wall temperature since the domain is big and it is required large mesh size? Best regards |
CFX Treatment of Laminar and Turbulent Flows | Jade M | CFX | 18 | September 15, 2022 07:08 |
Periodically fully developed (laminar and turbulent) flow and heat transfer within a | Abbas J | FLUENT | 0 | September 21, 2020 03:49 |
Why can i use a laminar solver for a turbulent flow? [Heat transfer problem] | blackbow | CFX | 1 | November 22, 2016 04:42 |
Heat transfer in rooms: laminar or turbulent? | ghost82 | FLUENT | 2 | February 13, 2014 08:47 |
Natural convection - Inlet boundary condition | max91 | CFX | 1 | July 29, 2008 20:28 |
