Surface tension UDF
Old   September 15, 2020, 16:41
Default Surface tension UDF
Dico Nico
Diconico is on a distinguished road
Is there a way to modify the models of Surface tension of fluent by an UDF?
I want to propose a new way to calculate the normal, or implement a model of the literature.
Is it possible?
Diconico is offline   Reply With Quote
Old   March 10, 2021, 16:07
Venkat Ganesh
Venky_94 is on a distinguished road
Is it possible?
It is possible to do that by adding the surface tension force as a source term using a UDF, however I'm still trying to figure out how to do that for my research work right now. Have you made any progress on that front?
Venky_94 is offline   Reply With Quote
Old   March 12, 2021, 12:01
Yasser Selima
Yasser is on a distinguished road
Use Define_Property macro
Yasser is offline   Reply With Quote
Old   March 12, 2021, 13:38
Venkat Ganesh
I need to modify the interface curvature term in CSF model, and hence need to replicate the CSF model with the changes and hook that as a source term.
I do not need to define the "surface tension coefficient", that is a fixed value in my case, like 0.072N/m.
If someone has worked on anything similar and has a sample UDF, that would be great because I wrote a UDF but I do not know what to type in for the dS[eqn] part. I could not understand that from the Fluent theory manual. I could use all the help I can get.
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
How to add Surface Tension in cavitatingFoam solver jamestangx OpenFOAM Programming & Development 1 April 6, 2016 17:39
Surface Tension Force Model Miguel CFX 7 October 2, 2006 06:30
surface tension gradient on a free surface Abrem FLUENT 1 April 30, 2006 04:41
surface tension model in EX26 Junhua Wu FLUENT 0 June 7, 2000 11:49
