September 12, 2020, 10:46 |
complile error for udf
aref
Rep Power: 7 |
Hello ever one. Im using ansys 2020R1 and visual stuido 2017 but when i want compile my code in UDF i get the following error:
The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64). What should i do? |
September 18, 2020, 06:03 |
#2 | |
Rep Power: 6 |
Fluent uses different executables for each of these "versions": Code:
2d 2d_host 2d_node 2ddp 2ddp_host 2ddp_node 3d 3d_host 3d_node 3ddp 3ddp_host 3ddp_node Have a look at the addons directory of the fluent installation Folder to see how this should look like! |
compile error, fluent - udf |
[OpenFOAM.com] complile v2006 with runTimePostProcessing functionality | snak | OpenFOAM Installation | 2 | August 1, 2020 08:08 |
UDF errors when complile | flo90000 | Fluent UDF and Scheme Programming | 5 | August 31, 2016 01:26 |
complile the Doxygen(source guide) of foam-extend-3.0 | bieshuxuhe | OpenFOAM Installation | 3 | May 11, 2014 15:42 |
about complile UDF problem. | Devy | FLUENT | 7 | April 18, 2003 10:23 |
