What is the equation or formula to calculate Mass Flux[kg/mēs] of species in Fluent?
Old   September 11, 2020, 02:10
Default What is the equation or formula to calculate Mass Flux[kg/mēs] of species in Fluent?
THA SEANGHAI
THA SEANGHAI is on a distinguished road
Hello! In Fluent, I am curious about how to calculate mass flux of a species [kg/mēs] from the mass fraction of that species which has density=0.25kg/mģ, that species was applied to a Wall BC (Horizontal line), there are no Normal velocities (Y-velocity) on that wall, but there are axial velocities (X-velocity) on that Wall boundary. That species has a Molecular weight=6kg/kmol. Note that there is only one species on that Wall boundary. In fluent, to set up that wall boundary, there is also the species tap to let us to fill out the mass fraction, so I put mass fraction=1, because there is only one species on that boundary. Therefore, how can I calculate the mass flux of that species [kg/mēs] from the detailed information that I provide? Or if you want more information, I can provide you further. It is the equation for calculating mass flux before running calculation in fluent, because after running calculation, I will get the results and I will calculate mass flux from those results by the equation provided by fluent: Ji=((density*Diffusion coefficient of a species)+(density*Effective diffusion coefficient of turbulent flow))*mass fraction gradient, then take this results to compare with the flux before running calculation. In this problem, I just want to know the equation or formulas to calculate that mass flux of a species before getting the results from fluent. Thank you! I will appreciate your help.
Last edited by THA SEANGHAI; September 11, 2020 at 02:29. Reason: Add some more infomation
THA SEANGHAI is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Multi Species Problem (mass fraction) usamaperwez CFX 0 July 27, 2016 08:07
How does FLUENT calculate turbulent mass diffusivity (m2/s) for the granular phase zhouwu FLUENT 0 August 6, 2011 05:51
mass fraction of species Ahmed FLUENT 0 April 18, 2007 12:57
