forced convection in Fluent
Old   September 7, 2020, 14:23
Default forced convection in Fluent
Ivan
ikki9001 is on a distinguished road
Hi everyone,
I need to calculate via Fluent the cooling of a 1300 K titanium sample immersed in a fluid that flows at 300 K (and therefore the heat exchange between them) for a transient of 15 seconds. By doing the simulations, in addition to having set the boundary conditions, through Cell Zone Conditions, I see that I can only set a fixed value of the temperature, so the simulation only shows me how the fluid warms up, and not how the specimen cools.
Through the named expression I tried to set up a cycle of this type and defining:
TStart = 1300 [K]
TTarget = 1000 [K]
TMin = Minimum (TotalTemperature, ["heatcube"]
TCurrentCube = Average (TotalTemperature, ["inlet"], Weight = None) {inlet = 300 K}
TAdjust = TCurrentCube + (TTarget-TMin) * relax {relax = 0.9}
TCube = IF (iters_per_timestep <10, TStart, IF (mod (iters_per_timestep + 1,30) == 0, TAdjust, TCurrentCube)) {iter / time step = 30 in Run Calculation}
And I impose TCube in the Boundary Conditions -> Wall -> {for all the walls adjacent to the specimen}.
but this method doesn't work and I don't know how to implement it on UDF. I have also tried using the patch command in Initialize, but the specimen temperature still doesn't decay. Can anyone kindly help me?
regards
ikki
ikki9001 is offline   Reply With Quote
Old   September 8, 2020, 05:56
Moritz Kuhn
MKuhn is on a distinguished road
I would do it in this way. Start with a steady state solution. The cold titatnium sample in the 300 K flow, solve until convergance. Then switch to transient, go to the initialization panel and patch only the temperature of the titanium cell zone to 1300 K - start the simulation with small time steps. In this way the temperature of the titanium will decay and you do not need an UDF.
MKuhn is offline   Reply With Quote
Old   September 8, 2020, 06:58
Ivan
Hi MKuhn,
I'll try your step. Thx very much
Forced Convection Process In Ansys Exterot ANSYS 0 March 23, 2019 15:26
Is it possible to model natural convection in a 2D horizontal model in fluent caitoc FLUENT 1 May 5, 2014 14:32
heatsink with forced convection siva FLUENT 0 September 26, 2008 01:05
Turbulent Forced Convection Tim FLUENT 1 October 1, 2006 08:41
Forced Convection Tim FLUENT 4 October 1, 2006 01:48
