saturated tank modelling using VOF
Old   September 5, 2020, 08:38
Lightbulb saturated tank modelling using VOF
ram_call's Avatar
ram
ram_call is on a distinguished road
I am simulating an initially saturated tank with refrigerant that the same flow enters 5K subcooled. I used pseudo-transient VOF model with dispersed interface, evaporation and condensation mass transfer. mass flow inlet and pressure outlet BC.
I have the following doubts/questions :
1) at first the outlet mass flow rate is higher than inlet, then it get close to inlet flow gradually. Also without any flow rate at initial runs, the outlet mass flow rate has values! why is that?
2) After some iterations, the temperature in the liquid domain lowered, but liquid volume fraction decreases. It seems liquid is evaporating and no gas is condensing. Why is that?
two mass transfer mechanism of the same type are active from liquid to gas and from gas to liquid (evaporation/condensation)
ram_call is offline   Reply With Quote
Old   September 6, 2020, 11:54
ram_call's Avatar
ram
The photos of liquid volume fraction and temperature are attached.
saturated, two-phase flow, vof simulation
Modelling falling solid sphere using interFoam VOF model eelcovv OpenFOAM Running, Solving & CFD 6 August 7, 2021 22:52
VOF modelling, water drainage from an elevated tank ashraf88 FLUENT 5 November 29, 2013 09:05
how to apply VOF in a tank??? HAYATE CFX 9 December 15, 2007 23:01
sliding mesh for stirred tank modelling Gopal Kasat FLUENT 0 June 24, 2005 06:38
Modelling flow around a ship's hull using vof Manoj Kumar FLUENT 0 February 26, 2005 17:22
