Sun Collector Cfd Analysis
Old   September 2, 2020, 10:48
Default Sun Collector Cfd Analysis
Hüseyin Can Sülük
HuseyinCan is on a distinguished road
Hello guys nowadays i am working on a sun collector system which can be described as follows:
Sun collector part which is contain coper pipes and covered by condensers and heated by sun then this heated fluid is storaged in an insulated tank
This storaged and heated fluid than transfersit is heat to air in an another device and after this cycle ,it enters copper pipes again.
My problems are:
-I have started to work on a system which has one velocity inlet and pressure outlet and simulation results wasnot satisfying and also i couldnt achive my goal which was describing inlet with respect to outlet temp.
My question is:
-What method should i use to change inlet with respect to outlet values?
HuseyinCan is offline   Reply With Quote
Old   September 3, 2020, 05:12
Moritz Kuhn
MKuhn is on a distinguished road
Starting from ANSYS 2019 R3 your are be able to define a function for the inlet temperature in dependence from another temperature (which you have to define first via report defintion) directly at the Boundary Condition Dialog Box.
In older Fluent versions you have to define a UDF function.
MKuhn is offline   Reply With Quote
Urgent - Perform an DISCRETE adjoint analysis in parallel_computation JPBLourenco SU2 1 April 23, 2018 11:38
Explicit dynamics results for initial condition to another explicit dynamics analysis KOI Structural Mechanics 0 March 2, 2018 05:16
How to implement a sensitivity analysis for certain items Mason liu CFX 10 August 17, 2017 09:46
FSI-system coupling: "...same analysis type"? rjw CFX 0 March 26, 2017 08:25
ANSYS WORKBENCH Transfer result of one analysis to a new analysis as preload ingjuanm90 ANSYS 0 July 26, 2016 15:04
