WARNING:Solution point management entries are corrupt
Old   September 2, 2020, 05:14
Exclamation WARNING:Solution point management entries are corrupt
白晓
xr bai is on a distinguished road
HELLO,everyone.
I am simulating the unsteady cavitating flow around a hydrofoil. The mesh is Cartesian cut-cell mesh and has been adapted according to iso-value in FLUENT. The numerical simulations are carried out by parallel processing in LINUX system. The warning showed up after the adaption during reading dat file as follows:
Reading "997w-corrected-adapted-les-cav-timestep-repaired-14-09500.dat"
Parallel variables
Warning: Solution point management entries are corrupt
Done.
Although the simulation can continue, but the residuals of all terms are not printed anymore. I want to know what caused the problem. THANK YOU very much!
xr bai is offline   Reply With Quote
adaption, cutcell, fluent, warning
solids4Foam + sixDoFRigidBodyDisplacement Michael@UW OpenFOAM CC Toolkits for Fluid-Structure Interaction 31 April 28, 2024 12:55
CFX Post: Problems with moving point cloud for changing time steps spatialtime CFX 0 December 7, 2009 05:56
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 03:27
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
