Non-eq. porous model, source using Temp of fluid and solid zones
Old   August 31, 2020, 12:09
Default Non-eq. porous model, source using Temp of fluid and solid zones
Franz Roman
franzdrs is on a distinguished road
Hello, I want to use an energy source in a non-equilibrium porous medium. In the non-equilibrium model there are two spatialy coincident zones, one for the fluid and one for the solid. The value of my source in a given cell depends on the temperature difference between the fluid temperature and the solid temperature in that cell. I want to assign the source term to the fluid zone. The DEFINE_SOURCE macro does the looping itself, so to access the fluid temperature I can just use C_T(c,t). But how do I access the solid temperature in the same cell?
Thanks
Franz
franzdrs is offline   Reply With Quote
non-equilibrium model, porous media model
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
