August 29, 2020, 20:22 |
Setting up operating density in fluent
ashish
Rep Power: 12 |
I am solving a natural convection problem in a square cavity with solid-liquid phase change and gravity in negative Y- direction. I have written a UDF for density as function of temperature.
I have specified operating temperature to phase change temperature. Do I need to specify operating density also. Density in my problem varies from 905 to 928. I tried with giving specific density equal to 900 kg/m^3. But the solution is not converging. However, when I disable the operating density I'm getting convergence. Should I go ahead without specifying operating density. Kindly Help. Thanks |
fluent, natural convection, operating density |
Setting mixture properties (density) | Anshs | FLUENT | 7 | June 3, 2020 08:43 |
Mixture Model and operating density | RodriguezFatz | FLUENT | 5 | February 20, 2019 03:16 |
Questions about operating conditions setting in fluent. | Frank Yang | FLUENT | 6 | May 18, 2013 05:08 |
Setting Density for Velocity Inlet Face | arkie87 | FLUENT | 0 | November 7, 2012 16:15 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 09:23 |
