Mesh Motion reference frame directions
Old   August 21, 2020, 11:11
Post Mesh Motion reference frame directions
sbuanzi is on a distinguished road
Hello everyone,
I'm simulating pitching motion of a 3D wing. The model has 2 O-blocks, communicating via mesh interface. The whole inner block, containing the wing, rotates according to UDF that defines the angular velocity which is the input of the block Mesh Motion (pitching is about Y axis).
The simulation is converging, but I get some strange values of the coefficients. Moment coefficient is as expected, also Lift coefficient shows reasonable values. As for drag coefficient I get negative values that are the opposite of the expected values. I obtain forces coefficients by projecting X and Z coefficients with respect to the angle of attack at each time step. I get X and Z forces by setting directions as (1 0 0) and (0 0 1) respectively, but I'm not sure whether these directions are inertial to the body, so "rotating" together with the block, or rather fixed with the absolute reference frame.
Can anybody help me?
Thank you in advance.
sbuanzi is offline   Reply With Quote
angle of attack, fluent, forces, mesh motion, pitching
Abnormal result of dynamic mesh motion at the between bottom and side boundary. blue8803 OpenFOAM Running, Solving & CFD 7 July 2, 2020 06:46
Different zone motion and mesh motion preview aamer FLUENT 5 September 24, 2012 14:58
Dynamic moving mesh Pei-Ying Hsieh (Hsieh) OpenFOAM Running, Solving & CFD 64 June 7, 2012 11:04
Prescribed mesh motion does not correspond to actual motion rbarrett CFX 8 June 30, 2011 14:22
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
