Near-Critical CO2 flow analysis-pressure drop problem
Old   August 21, 2020, 10:33
Exclamation Near-Critical CO2 flow analysis-pressure drop problem
ANTALYA
erginbayrak is on a distinguished road
We have been numerically investigating the thermal-fluid characteristic of sCO2 laminar flowing in a 0.5 mm diameter circular microtube in upward direction. Depending on sharp density change along the tube, this case can be admitted as a compressible flow. When applied pressure-based solver option, the pressure firstly decreases until a certain point along the tube, then increases towards the outlet. So, this situation is impossible. Although the entire graph is very reasonable, the pressure change along the flow direction is interesting as seen in the attached file. When calculated theoretically (considered friction depending on both wall shear and momentum change) by using Ansys data (wall shear stress, density, axial velocity, etc.), the pressure drop is found as expected (full decreasing along flow direction).
erginbayrak is offline   Reply With Quote
fluent, micro channel, supercritical co2
Which pressure drop has to be chosen? (Pipe laminar flow) liliana FLUENT 14 June 19, 2022 12:22
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Pressure drop error of laminar pipe flow with simpleFoam xiaolong OpenFOAM Verification & Validation 4 September 22, 2019 06:07
Match Pressure Inlet/Outlet Boundary Condition Mass Flow Rate MSchneid Fluent UDF and Scheme Programming 3 February 23, 2019 07:00
Pipe Flow - Pressure Drop Daniel L FLOW-3D 2 December 10, 2010 05:23
