Giulio Remo Cupilari
Rep Power: 0 ![]() |
Dear sir/madam,
I am trying to animate the velocity magnitude from a 3D file on a HPC cluster. I have attached the journal file I am using and the returned output file with the error. When I run the commands in the Fluent command prompt, they work but in the cluster they keep returning errors of invalid surfaces/commands. How can this be fixed? Is there a mistake in the journal file? Thank you for your help. |
Steven Xu
Hello, have you solved the issue you mentioned before? I met the same issue now, can you support to input the correct journal file
Multi-cellzone 3D mesh Fluent import issue | Idanst | Pointwise & Gridgen | 6 | November 16, 2017 11:41 |
Animation of Fluent transient data | saisanthoshm88 | CFX | 22 | August 14, 2017 19:06 |
Animation of Fluent transient data | saisanthoshm88 | FLUENT | 2 | December 18, 2012 09:51 |
Loading Animation Sequence in FLUENT Produces Blank Screen | SeanQuallen | FLUENT | 0 | February 17, 2012 09:56 |
Generating animation in fluent 13 | QBeast | FLUENT | 0 | July 17, 2011 10:54 |
