Real Gas Model Mixture in Fluent
Old   August 14, 2020, 14:04
Default Real Gas Model Mixture in Fluent
Olmo
Olmo95 is on a distinguished road
Hello everyone,
I am trying to simulate a Heat Exchanger using real gas mixture of supercritical CO2 with other species (COS, NH3, H2S, SO2). I am using the NIST Real Gas Model, which worked well with the pure s-CO2 simulation. But I have several errors when launching the mixtures. I was able to run the mixture s-CO2/H2S and it converged, but for the rest of the mixtures there are errors that do not allow me to run the simulation. I am not sure if the problem is that I am not using the NIST model properly or that the mixtures I want to run are difficult with this model. I am trying converge the solution using first-order discretization as adviced by the Fluent Manual.
Boundary conditions:
- Hot inlet: Velocity 4.702 m/s
- Cold inlet: Velocity 0.843 m/s
- Hot outlet: Pressure 90 bar
- Cold outlet: Pressure 225 bar
I have attached some images of the setup for the NIST model and also some of the errors I am facing. I also attached an image of the geometry I am using.
I hope someone can help me with this problem. Thank you in advance.NIST setup1.PNG
Olmo95 is offline   Reply With Quote
heat exchange, mixture of gases, nist real gas model, real gas model
make a new data from external .txt data and save it in a UDM etedalgara Fluent UDF and Scheme Programming 27 February 26, 2020 04:15
FLUENT 19.2 User Defined Real Gas Model udf problem MKPP FLUENT 1 June 23, 2019 22:39
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 06:37
Erron: FLUENT received fatal signal (ACCESS_VIOLATION) in DPM Heat and Mass Transfer Melvin FLUENT 2 November 17, 2016 02:06
Parallel User Defined Real Gas Model aeroman FLUENT 4 July 1, 2015 07:09
