why exported xy data will jump regarding to position in fluent? |
Weiqiang Liu
Rep Power: 9 ![]() |
Hi all,
I tried to export xy data in a two dimensional case. x is position coordinate and y is exported values. I found that exported data will suddenly jump from one position to a far away position. For example, the whole length of the two D surface is 15 mm, the exported position would jump from 3 mm to 7 mm. However, the exported positions should be node coordinates in the mesh I believe. In some other cases, this jump does not happen in which I can export continuous xy data. The node distribution is same in these cases. I am wondering why would this jump happen? ps: I just used the imbedded post processing tool of fluent Best regards weiqiang |
jump, post processing, xy plot |
Stopping a Fluent batch job AND saving the data! Possible? | Volker Pawlik | FLUENT | 13 | December 28, 2020 04:16 |
high continuity Fluent modeling ABL with WRF/CALMET data | xitao21 | FLUENT | 1 | May 2, 2019 10:20 |
External Magnetic Field Data Format for FLUENT MHD Module | eduardvinter | FLUENT | 0 | January 24, 2019 01:54 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
