Fluent DPM particle-adding problem
Old   August 4, 2020, 23:30
Default Fluent DPM particle-adding problem
Brandon Han is on a distinguished road
Hello everyone, this is Brandon Han. I have a problem about Fluent DPM and I really hope someone can help me.
I'm working on a transient coal combustion simulation using Fluent DPM model. I use injections to describe coal which is added into the furnace at regular intervals. I'm using "surface" to add coal into the furnace in injection. What I'm trying to achieve is to add 15 particles every 15 seconds. The coal-adding surface is divided into 15 small faces. If I set "flow rate" to a number which is lower than one particle mass, then the coal won't be added into the furnace. I have to increase the "flow rate" to a number which is larger than one coal mass. However, the numbers of coal particles added into the furnace is more than expected. I tried to increase "particle time step size". increasing from 1 to 6 worked, but failed from 6 to 10. It's still a little far from satisfaction from what I expect.
What I'm trying to do is add 15 particles in 15 seconds by surface adding in injections. But either setting flow rate or increasing particle time step cannot meet the demand.
I will really appreciate it if someone can give me some advice.
Thanks in advance.
Brandon Han
Brandon Han is offline   Reply With Quote
dpm, fluent, injection, particle time step size, particle-adding
How can I make a particle reach a wall as close as possible in FLUENT DPM? Jazz FLUENT 2 June 10, 2022 07:29
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
Problem with Boundary UDF for DPM - Updating particle position FarzinD Fluent UDF and Scheme Programming 0 July 28, 2015 13:39
injection problem Mark New FLUENT 0 August 4, 2013 02:30
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 03:00
