OK
Rep Power: 0 ![]() |
Dear all:
I conducted a water-solid DPM simulation in a multistage-centrifugal pump and extracted impact information (angle, speed, hits number) through UDF to study the erosion results. Questions are: 1. When I use the sliding mesh method (for the rotating impeller), I got negative impact angles on the blades. Does anyone know what's going one there? 2. When I use the frozen rotor method (for the rotating impeller), the erosion results are fine. But the frozen rotor method has its own problem with the pump, especially for multistage pumps. I would prefer sliding mesh if the problem was solved. Thank you for the help! |
centrifugal pump, dpm, erosion, impact angle, sliding mesh |
Strange behavior of water surface near solid body | JBrake | OpenFOAM Running, Solving & CFD | 6 | January 16, 2019 17:51 |
No conjugate heat transfer between solid (cast iron) and fluid (water) | Rajaero | Main CFD Forum | 1 | August 23, 2018 13:01 |
simulation with dpm : exchange of heat with a solid | cdiako | Fluent UDF and Scheme Programming | 1 | June 17, 2016 08:28 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
