2D rotating detonation simulation - UDF inlet BC
Old   July 23, 2020, 02:57
Default 2D rotating detonation simulation - UDF inlet BC
Tianxu Yin
Tianxu is on a distinguished road
Hi guys,
This is quite urgent!
I am doing 2D rotating detonation engine (RDE) simulation in ANSYS Fluent.
For pressure inlet boundary condition, there are three possible cases:
1. Pi > Po, where Pi is the pressure inside the domain immediately at the inlet and Po is the total inflow pressure. In this case the pressure inside the RDE at this point is very high and blocks inflow of new mixture through the inlet face. The inlet boundary acts as a wall.
2. Pcr < Pi < Po, where Pcr is the critical pressure. In this case the inlet is not chocked and new mixture flows into the RDE according to: mass flow rate = the integral of (rho*u*dA).
3. Pi < Pcr, in this case the pressure inside the domain is low. The inlet at this point is choked, so maximum flow rate of fuel is flowing into the domain. Pcr is calculated from isentropic relation.
My UDF (mass flow rate inlet BC) compiles successfully which means the code is grammatically correct. When I tried to initialise the solution, the following errors appeared.
Node 0: Process 3524: Received signal SIGSEGV.
Node 1: Process 10032: Received signal SIGSEGV.
Node 2: Process 11508: Received signal SIGSEGV.
Node 3: Process 12336: Received signal SIGSEGV.
999999: mpt_accept: error: accept failed: No error
MPI Application rank 0 exited before MPI_Finalize() with status 2
The fl process could not be started.
I tried standalone mode of Fluent, it also didn't work....
I think this may because the logic of the code, or this UDF is not suitable for Fluent.
My code is the following:
#include "udf.h"
DEFINE_PROFILE(inlet_mf,th,i)
face_t f;
cell_t c;
Domain *d = Get_Domain(1);
Thread *t = Lookup_Thread(d,5);
real pw;
real po;
real pcr;
real To;
real gamma;
real v;
real vmax;
real R;
real rho1;
real rho2;
real area;
real A[ND_ND];
R = 368.9; // J/kg k
gamma = 1.29;
po = 1013250;
pcr = po * pow( (2/(gamma+1)), (gamma/(gamma-1)) );
To = 300;
vmax = sqrt( (2*gamma/(gamma+1)) *R*To );
begin_f_loop(f,th)
pw = F_P(f,th); //pressure on one face
F_AREA(A,f,th);
area = NV_MAG(A); // Find area of one face
if(pw >= po)
F_PROFILE(f,th,i) = 0.0000001;
else if(pw > pcr && pw < po)
v = sqrt( (2*gamma/(gamma-1)) *R*To * (1 - pow(pw/po, (gamma-1)/gamma)) );
rho1 = F_R(f,th);
F_PROFILE(f,th,i) = rho1*v*area;
else if(pw <= pcr)
rho2 = F_R(f,th);
F_PROFILE(f,th,i) = rho2*vmax*area;
end_f_loop(f,th)
Could anyone give me some advises and help?
Thanks very much!
Tianxu is offline   Reply With Quote
Old   July 23, 2020, 03:22
Tianxu Yin
For someone may get confusion. I'm adjusting mass flow inlet.
Old   July 23, 2020, 03:39
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
code seems to be good,
the only thing you can do, which is not mandatory, you can add math library
#include "math.h"
are you sure you are using small enough timesteps?
when did you get this error? on the first iteration?
you may check, if the problem in UDF or not, using very simple profile
#include "udf.h"
face_t f;
begin_f_loop(f,th)
end_f_loop(f,th)
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   July 23, 2020, 03:57
Tianxu Yin
#include "math.h"
#include "udf.h"
face_t f;
begin_f_loop(f,th)
end_f_loop(f,th)
Thanks for the reply!
The error appears when I initialise the domain. I wasn't able to run the simulation.
I tried to add ''#include math.h", it still didn't work..
Regards
Old   July 23, 2020, 04:13
Alexander
did you try simplified code?
may be the problem with your code is that you are using pressure and density.
to initialize domain fluent applies boundary conditions
In other words there is no pressure and density yet
what you can try, initialize your case with constant mass-flow value and hook profile after that
best regards
Old   July 23, 2020, 04:22
Tianxu Yin
That sounds a good idea, I'll get back to you once I try that!
Thanks
Old   July 24, 2020, 01:15
Tianxu Yin
I initialize the case with constant mass-flow inlet value and ambient pressure value. Once I tried to hook the UDF on mass flow BC, the same error appeared.
In my code, I used F_R, do I need to get the density value from a cell rather than a face?
Regards
Old   July 24, 2020, 02:33
Tianxu Yin
I also tried simple mass flow UDF. It compiles and runs safely. I think the problem may relate to logic problem...
Old   July 24, 2020, 03:57
Alexander
I think, that you need values from surface, not from the cell
you can add condition to check, if the face belongs to boundary or not
if (BOUNDARY_FACE_THREAD_P(t))
#include "udf.h"
face_t f;
cell_t c;
real pw;
real po;
real pcr;
real To;
real gamma;
real v;
real vmax;
real R;
real rho1;
real rho2;
real area;
real A[ND_ND];
gamma = 1.29;
po = 1013250;
To = 300;
begin_f_loop(f,th)
	F_AREA(A,f,th);
	if (BOUNDARY_FACE_THREAD_P(th))
		if(pw >= po)
		rho1 = F_R(f,th);
		else if(pw <= pcr)
		rho2 = F_R(f,th);
end_f_loop(f,th)
best regards
Old   July 27, 2020, 03:27
Tianxu Yin
#include "udf.h"
face_t f;
cell_t c;
real pw;
real po;
real pcr;
real To;
real gamma;
real v;
real vmax;
real R;
real rho1;
real rho2;
real area;
real A[ND_ND];
gamma = 1.29;
po = 1013250;
To = 300;
begin_f_loop(f,th)
	F_AREA(A,f,th);
		if(pw >= po)
		rho1 = F_R(f,th);
		else if(pw <= pcr)
		rho2 = F_R(f,th);
end_f_loop(f,th)
I modified the UDF to hook velocity inlet BC, it works fine with no chemistry. The inlet velocity could be adjusted according to wall pressure.
But once I import chemistry (hydrogen air mechanism with 23 reactions and 9 species), the same error appeared. Is my UDF able to work to import chemkin mechanism? I'll attach my code to the next post.
Regards,
Old   July 27, 2020, 03:28
Tianxu Yin
The up-to-date velocity inlet UDF:
#include "udf.h"
DEFINE_PROFILE(inlet_velocity,th,i)
face_t f;
cell_t c;
real po;
real pcr;
real To;
real gamma;
real R;
real p_cur;
po = 1013250; // stagnation pressure
gamma = 1.29;
pcr = po * pow(2/(gamma + 1), gamma/(gamma-1)); // critical pressure
To = 300; // stagnation temperature
begin_f_loop(f,th) //to find pi, pressure inside the domain immediately at the inlet
p_cur = F_P(f,th); //pressure on one face
if(p_cur >= po)
else if(p_cur <= po && p_cur > pcr)
F_PROFILE(f,th,i) = sqrt( 2*gamma/(gamma-1) *R*To * (1 - pow(p_cur/po, gamma-1/gamma)) );
else if(p_cur <= pcr)
F_PROFILE(f,th,i) = sqrt(2*gamma/(gamma+1) *R*To);
end_f_loop(f,th)
DEFINE_PROFILE(inlet_temperature,th,i)
face_t f;
real To;
real p_cur;
real po;
real gamma;
gamma = 1.29;
F_PROFILE(f,th,i) = To * pow(p_cur/po,(gamma - 1)/gamma); // Temperature
end_f_loop(f,th)
Rotating motion simulation in fluent yusuf.5ayat ANSYS 0 January 10, 2017 07:18
Udf to measure radius of inlet as it changes - FSI simulation DamR Fluent UDF and Scheme Programming 0 December 28, 2016 03:54
How to set unsteady turbulent inlet velocity using the result of another simulation? John-Lee FLUENT 2 December 27, 2016 18:36
Doubts in injection mould simulation (inlet conditions, temperature...) jpina FLUENT 7 October 3, 2016 09:14
UDF: Change boundary condition. Velocity inlet to pressure inlet at time "t" jpina FLUENT 10 April 11, 2015 15:19
