Simple Box - Gravity with Pressure Outlet - Unrealistic Reverse Flow |
July 22, 2020, 13:36 |
Bs
Hi all
I intend to simulate a tidal turbine in a tidal current. First, I am trying to test the application of gravity/hydrostatic pressure gradients to a simple box of sea water of the same dimensions as my domain so that I can get this right before adding the turbine. Inlet velocity 0.1m/s, the nearest wall to the right is inlet (flow in +y direction) Seawater properties: density 1024kg/m3, visocisty 0.00111 the domain is 48x48x80m Gravity applied with operating density 0 A reference pressure at the origin represents that which would be experienced at 24m depth below sea level (about 340,000Pa) pressure outlet with 0 gauge pressure Remaining boundaries are walls using k-w SST Coupled method Coarse mesh for the sake of this experiment As you can see I am getting a bizarre reverse flow circulating flow pattern, as well an incorrect and inconsistent pressure values along the height of the box. I think the issue is with the pressure outlet: by applying a fixed pressure at outlet and applying gravity to the domain so that fluid with a pressure gradient arrives at the outlet, the velocity at outlet has to vary along the outlet to change pressure to a constant value? I have selected average pressure specification, I am not sure how else to allow fluent to maintain the pressure gradient at outlet. The values of pressure at top and bottom (Z direction) are not as expected and not consistent along the flow path - the upper boundary should see 1atm pressure as if it is sealevel. I believe the pressure contour shows relative/gauge pressure, so max and min should be about +-2.4e5Pa I have been able to achieve a more realistic result (consistent and correct pressure gradient, max and min pressure expected, relatively smooth flow from inlet to outlet) by applying mass flow inlet and outlet. This is fine for a confined channel but is not applicable to my physical scenario and as such shouldnt be used. As I say I think this is an issue of the options selected for the pressure outlet, but I am not sure. Any advice is great! |
July 23, 2020, 10:02 |
Bs
For reference, this is what I would like to achieve (attached)
This is by applying gravity along with equal mass flow inlet and outlet |
December 1, 2021, 18:31 |
Chris
Rep Power: 5 |
I know this is an old post but I have recently encountered a similar problem. I haven't completely solved this issue but what I did do is specify the outlet pressure profile with a UDF to be (rho*g*h) the hydrostatic pressure. There is still a small discontinuity in the pressure gradients of the outlet and interior domain. This significantly reduced the reverse flow but the pressure gradients do not perfectly align hence there is still reverse flow. I'm still working on a solution. I cannot use outflow in my case because I have incompressible flow.
Were you able to find a solution? |
gravity, hydrostatic pressure, pressure gradient, pressure outlet, reverse flow |
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 13:23 |
Pressure inlet vs outlet position, transient, time dependent pressure and gravity | silent2608 | FLUENT | 0 | February 6, 2016 11:19 |
changing velocity (outlet) BC to pressure outlet | majid_kamyab | FLUENT | 7 | October 22, 2014 12:50 |
simple model, difficult outlet | Eric | CFX | 7 | May 23, 2014 09:13 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 16:00 |
