Modelling compressible diesel with cavitational effects |
July 22, 2020, 07:35 |
Maximilian Ringel
Rep Power: 6 |
I have to modell the compressible flow in which Diesel is used. Effects like cavitation should be implemented as well. Today I started modelling the compressibilty of diesel (diesel-liquid). Instead of using constant density, I selected "compressible liquid" and changed the Reference Density and the Bulk Modulus. (One thing I wasn't sure about is the Density Exponent, typed in "1" for it, but I don't know what that means...) After it, the calculation diverged after 4 Iterations. When using ideal gas, the calculation runs through, but with unrealistic density values (up to 1600 kg/m^3, instead of realistic 950 kg/m^3, which is normal because a gas can be compressed easier than a liquid and diesel is not a gas). I also tried to use the piecewise-linear function, but it is only possible to do this in terms of temperature. Is there a way to model this supposedly simple context? The dependency between pressure and density in my case can be described with a linear function, maybe a UDF can help but I don't know how to write it... Second thing is that it all has to work with cavitation, so later I'm going to use the Multiphase Mixture model, and for those cavitational effects the Zwart-Gerber-Belamri model will be used. |
compressible liquid, pressure and density, udf |
CFD in Naval Hydrodynamics, Off-Shore and Wave Modelling with OpenFOAM | hjasak | OpenFOAM Announcements from Other Sources | 2 | February 13, 2017 04:59 |
Simulation of high pressure diesel injector - all phases compressible with cavitation | fivos | CFX | 4 | July 30, 2015 06:48 |
Divergence problem on changing the materials to compressible | 0906536m | FLUENT | 0 | January 6, 2014 07:05 |
2D modelling and wall effects | ati_ros61 | FLOW-3D | 1 | September 2, 2010 22:06 |
Questions about radiation modelling | Yingchun | CFX | 5 | November 23, 2005 01:53 |
