Radiation-adiabatic wall
Old   July 21, 2020, 11:45
Default Radiation-adiabatic wall
CFDger is on a distinguished road
for my 2D problem setup I would like to model the wall between the external, hypersonic fluid (Ma 8, ..., 12), and the solid airfoil/geometry (which is meshed as a solid) as a radiation adiabatic wall.
To my understanding in theory this means that the heat conduction (gas->wall) equals the heat radiation (wall->gas). Please correct me if I'm wrong.
I know how to model the standard adiabatic wall aswell as the isothermal and coupled wall conditions as fluent makes setting these up quiet easy.
Which settings do I need to set to obtain a radiation adiabatic wall boundary condition?
I searched this forum and several papers for an answer but I couldn't find anything regarding the fluent setup.
Thank you very much for your help.
Best regards
CFDger is offline   Reply With Quote
Old   July 22, 2020, 05:13
Default Update Idea
My current idea is to write a UDF which describes the ratiation heat flux from the solid towards the fluid. If anyone has experience on this or suggestions why this should work or not I would be happy.
best regards
adiabatic, boundary condition, fluent, radiation adiabatic, thermal analysis
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Radiation Modeling Chris89 CFX 20 August 14, 2014 08:51
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 13:11
Radiation flux to the wall surface Jason Phoenics 1 May 26, 2004 02:13
