Problem in Ansys Fluent, Macroscopic Particle model(MPM)
Old   July 21, 2020, 11:35
Default Problem in Ansys Fluent, Macroscopic Particle model(MPM)
L.A.Isanka
Achini is on a distinguished road
Hello!
I'm trying to simulate a cinematographic separation using MPM(Macroscopic particle model) in Ansys fluent (2020 student version).
I have created a particle injection at the inlet of the channel and i'm using "particle track" option to tract the flow of the injected particle.
The problem is, when i run the simulation, the injected particles do not appear.
Can someone help me with this please?
Thank you!
Achini is offline   Reply With Quote
Old   February 1, 2021, 13:40
Ethan McGrath
mcgart25 is on a distinguished road
Did you manage to figure out what the issue was? I am having the same problem myself, in nothing happens when I click on 'display injection'. The only issue I can think of is that in the only tutorial I could find (on Youtube by a company called Difotech), they created some kind of ASCII file in the 'write particle data' section'. I am not sure if such a file is needed to allow initialization. However, I am not sure what kind of information this file needs to contain. If you did find the issue, could you please contact me?
mcgart25 is offline   Reply With Quote
fluent, mpm, separation
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 05:37
Problem with Results in ANSYS Fluent mattsarg55 FLUENT 6 August 6, 2019 13:06
Multi-phase Problem in Ansys Fluent. Deepakc Fluent Multiphase 0 June 25, 2019 06:59
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 20:12
error in ansys fluent while solving dynamic mesh problem of moving wall classified FLUENT 3 November 23, 2016 02:21
