Dynamic mesh of a simple piston
Old   July 20, 2020, 15:15
Question Dynamic mesh of a simple piston
yasssine
yassine_bouzouba is on a distinguished road
Hey everyone,
I am new to dynamic mesh. I do a project for the purpose of improving the turbulence inside a combustion chamber. But First, I need to simulate a proper Piston. So, I filled the parameters that I need as shown in the images. But, when I want to display the mesh, I get this error."Warning: Mesh projection of deforming dynamic zones exceeds reasonable limits.
Please verify that the correct geometry definitions have been specified."
Knowing that the cell height is 2mm.
yassine_bouzouba is offline   Reply With Quote
Old   July 20, 2020, 15:16
yasssine
here are other images.
dynamic mesh;
Reconstruction of the parallel case with dynamic mesh makaveli_lcf OpenFOAM Post-Processing 8 December 3, 2024 12:16
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
simple 2d open ended cylinder with moving piston: dynamic meshing query lmarf88 ANSYS 0 January 6, 2014 10:55
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? karkar OpenFOAM Meshing & Mesh Conversion 0 July 4, 2012 07:54
