July 20, 2020, 07:22 |
Photoacoustic/Optoacoustic Simulation
Ananya
Rep Power: 6 |
I am trying to create and analyse a photoacoustic system model. I have preapared an analytical model and have some value from it. Now, I am trying to create a FEM model of the system in Ansys 2019 R1. I use the academic license. I have following queries 1. Is it possible to simulate the photoacoustic effect using finite element simulation directly? As in, is it possible to define the incident radiation intensity, define the fluid propertieds and get the photoacoustic pressure/temperature at the output? 2. At present, I am trying to replicate the effect using Fluent, where I define a geometry, enclosure and boundary conditions and try to provide "periodic pressure inlet" and pressure outlet to induce the effect of light modulation (in turn, pressure modulation). If it is not possible to directly simulate photoacoustic effect in Ansys, how can I refine my second model? |
Convergence Problem - Transient Simulation | gemxx | Main CFD Forum | 0 | July 15, 2018 10:36 |
Mapping Field Data for Mesh Regions from Another Simulation | veterator | OpenFOAM Pre-Processing | 1 | July 10, 2018 06:28 |
Surface Source - Fixed Temperature? | robtheslob | FloEFD, FloWorks & FloTHERM | 18 | May 12, 2017 03:28 |
Simulation FPEs - turbulence for transient and steady-state? | DaveR | OpenFOAM Running, Solving & CFD | 5 | March 5, 2017 16:06 |
setting up a simulation with multiple interactions | phandy | OpenFOAM Running, Solving & CFD | 1 | October 6, 2014 04:16 |
