Axial Fan transient simulation results mismatch with datasheet
Old   July 20, 2020, 02:45
Default Axial Fan transient simulation results mismatch with datasheet
Varun V P
VarunV is on a distinguished road
Hello there,
I've been trying to simulate a small axial fan working as a suction device for an air quality sensor. The mass flow rate is something that needs to be accurate, and hence I started a transient simulation of the spinning fan, housed at the end of a box where the sensors will be.
Inlet is the at the left, and outlet is at the right, just after the fan. I have set both of them as a pressure boundary condition, 0 Pa.
I put an inflation layer on the blades surfaces, and I have proximity meshing enabled for the thin gap between the fan blade and the wall. Note that the wall around the fan blades is stationary, and I've made sure of this in the BCs.
The rest of the body I have meshed with MultiZone, and there is a nonconformal interface between these 2.
Now coming to the solver, I have used the SST model, with curvature correction and low reynolds number correction enabled. Please tell me if this is acceptable. I am using the sliding mesh method, and the fan is spinning at 6500 RPM.
Note that I disabled the average pressure specification because the solver gave a warning. I should have also disabled the normal to boundary condition.
These are the solution methods for the initial run.
After running for 500 timesteps, each of 0.0005 s, with 20 iterations each, I get a flow rate of around 46 lpm, which is 10 lpm higher than what the manufacturer states, for an atmospherics static pressure! I am now continuing the simulation with a second order run of the variables. I will attach the image of the wall y star values in the comments, if I can. They're all around 1 on the fan blade. Can anyone tell me what I'm doing wrong, and any recommendations to increase accuracy? Has anyone got such parameters to match to the simulation?
VarunV is offline   Reply With Quote
Old   July 20, 2020, 02:54
Default Some more images
Varun V P
I have attached images of the wall ystar on the fan blades, and a wireframe view of the mesh.
Old   December 3, 2024, 09:26
Cihan Demirci
cihan is on a distinguished road
4 years have passed since your question, but no one has answered it.
Actually, I'm curious about the answer too, I'm dealing with similar analyzes and I have some questions.
Maybe someone can shed some light on this??
cihan is offline   Reply With Quote
axial fan, sliding mesh, sst kw, transient analysis
Axial Fan Simulation monigabriela6 FLUENT 1 March 3, 2019 00:50
Transient Simulation in CFX ashtonJ CFX 1 September 28, 2018 02:18
Acoustic simulation of axial fan arunraj FLUENT 0 December 13, 2012 02:30
Batch issues to get results from a transient simulation aero ANSYS 0 November 10, 2009 07:32
flow simulation across a small fan jane luo Main CFD Forum 15 April 12, 2004 18:49
