Recirculation Outlet DPM Boundary Conditions
Old   July 17, 2020, 07:42
Question Recirculation Outlet DPM Boundary Conditions
Afief Riezaldy Ahmad
afiefaldy is on a distinguished road
Dear all,
I have a question regarding DPM BC settings in Recirculation Outlet, this is my project general descriptions:
1. I investigating particles' fates in an indoor flow simulation using Unsteady DPM, I'm using k-\epsilon turbulent model. My model consists of a room, two occupants, and an indoor unit split Air Conditioner.
2. The fluid domain's boundary conditions are:
- Velocity Inlet at ceiling supply diffuser
- Mass flow inlet at 1/2 inch gap under the door (doorgap)
- Outflow at exhaust fan
- Recirculation inlet and recirculation outlet at the air conditioner unit
3. Flow time is 180 seconds, 40000 particles injected at t=1s.
My problem is:
At the end of simulation, about 1% of the particles escape through the recirculation outlet, which i don't desire. The problem is, in the recirculation outlet boundary condition window there is no DPM BC options.
Since i only desire the particles to escape through the exhaust fan, this condition becomes a big problem for me.
My question is:
Is there any way to specify "reflect" DPM boundary condition at the Recirculation Outlet so the particles won't escape through that zone?
I really wish someone can come up with the solution, will be very grateful. Wish you all a great day.
afiefaldy is offline   Reply With Quote
Old   July 17, 2020, 19:15
Guvennergiz's Avatar
Guven Nergiz
Guvennergiz is on a distinguished road
Hello Afief,
Unfortunately i couldnt see recirculation inlet-outlet boundary condition in R19 and about all other conditions i can set DPM settings like you desired.
Also, if an air cond. reflects particles that it already sucked, this could be create wrong particle flow too. So, maybe you can assume %1 particle escaping (or trapping because air conditioner units have filters too) and injecting back (that %1) from recirculation-inlet with single-injection.
I hope you can solve this problem.
Best regards,
Güven
Guvennergiz is offline   Reply With Quote
Old   December 21, 2023, 05:08
Jessica Xu
Jessica_Xu is on a distinguished road
HI Afief,
I am also facing the same problem with Recirculation Outlet-DPM Boundary Conditions. If you have solved it, could you please give some suggestions about this issue?
Jessica_Xu is offline   Reply With Quote
3D Windturbine simulation in SU2 k.vimalakanthan SU2 15 October 12, 2023 06:53
outlet pressure Boundary settings -velocity streamline under ambient temp.conditions Vishnu_bharathi CFX 12 November 21, 2017 07:56
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 11:00
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 05:59
